SLP line lock questions...
Old Oct 18, 2003 | 01:57 PM
94foormula's Avatar
I just finished installing the line lock and I had a couple questions.
1. Does the placement of the spade connectors matter on the module?
2. On the switch, which way is on? On the switch I saw a little circle does that mean on?
3. How exactly does it work? I push the brake and flip on the switch, do my burnout and then flip the switch back? Is that it?
4. I bled all the brakes, do I need to bleed the ABS unit? I thought I read somewhere since the lines go from the master cylinder to the ABS unit there is no need to bleed the ABS.
Old Oct 18, 2003 | 04:36 PM
94foormula's Avatar
Can anyone help?
Old Oct 18, 2003 | 07:41 PM
94foormula's Avatar
No one knows??
Old Oct 18, 2003 | 08:14 PM
2cub49's Avatar
Hold the brake down and throw the switch. When you release the brake pedal the front brakes should stay locked while you spin the rears. When you throw the switch the other way the brakes will release. Personally I plan on installing a momentary on button on my shifter **** to better and more elegantly do the same thing as the supplied toggle.
Old Oct 18, 2003 | 08:16 PM
2cub49's Avatar
Can't help you with the other questions as someone else installed it for me.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Pampered-Z
Apr 14, 2015 05:38 PM
