slp header install
Old Apr 8, 2003 | 07:43 PM
ucantZme's Avatar
slp header install
ok, im ready ta shove them bastads in. i know that one side of the motor needs ta be raised, but which side?? pass. or driver?? i have the starter and the alt out already.
Old Apr 8, 2003 | 07:46 PM
Kris93/95Z28's Avatar
I didn't have to raise mine for my headers, but they weren't LTs.
I'd try to see if you could get them in with out raising the engine
If a side needed to be raised I would think it would most definantly be the passanger side
Old Apr 8, 2003 | 07:48 PM
94F1Z28's Avatar
You shouldn't have to raise the motor but you will probably need to remove the steering shaft.
Old Apr 8, 2003 | 07:51 PM
I'd try to put the headers in before removing abunch of stuff
If you haven't already SOAK the manifold bolts in a GOOD lubricant!!!!!!!!!
BTW: The driver side can go from the top if I remember right and the passanger has to go from the bottom
turbo_Z's Avatar
had to raise the drivers side... couldnt get them to fit on mine or claudes car without doing it. i suggest putting in the drivers side first.
Old Apr 8, 2003 | 08:06 PM
ucantZme's Avatar
well i dont gta soak any thing since the stock mans are already out and have been for about 4 days or so. thanx brad, i'll try that first.
Old Apr 8, 2003 | 08:27 PM
Z95m6's Avatar
i had to jack the drivers side up too. I messed around for more than an hour trying to get the header in without jacking it up but in the end i jacked it up. It took less than 20 min. to do so.
Old Apr 8, 2003 | 09:49 PM
burnemonm1's Avatar
I was able to slide mine up the passenger side (from th bottom) no prob. the drivers side I tried putting in from the top couldn't do it tried from the bottom, no dice. then I tried from the top again and with a little finesse they slid in. I didn't remove anything besides the 2 rear plugs on the drivers side and the alternator on pass.
Jlo
Feb 23, 2015 12:20 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
