Slp Cold Air
Old Oct 29, 2003 | 05:33 PM
CamaroZ28LT1's Avatar
Slp Cold Air
ok iv only been on here for a few weeks now. i have a 1997 Z28 camaro 6spd. its a nice car but im trying to put some basic mods to start off. so far i installed the 160 deg thermostrate but i was curious if there was any real way to put in on. i just took the part off and switched therostrats. was that the right thing to do?? plus i just recieved a SLP cold air intake, i need some pics so i can see step by step install could anyone help me out. sorry im new at this. thanks josh
Old Oct 29, 2003 | 05:43 PM
ibanez6rg's Avatar
Did you bleed the system when you finished up?
The CAI is easy to install. Rip out the old and in with the new. Really, it's simple
Old Oct 29, 2003 | 05:44 PM
drewstealth's Avatar
Yeah that is all you really gotta do for the thermostat swap. But to take full advantage of it you might wanna get your fans reprogramed to come on sooner. Or you can get a manual fan switch. I have the SLP CAI. I just used the instructions it came with. It is pretty easy to do. It looks really good and i believe it provided about 7-10 rwhp.
Old Oct 29, 2003 | 05:45 PM
zoso1959's Avatar
Re: Slp Cold Air
sounds like your gonna have fun,
you'll have to install manual fan switch to turn your fans on early or reprogram your pcm.
your temperture will still rise, untill the fans come on from the factory settings.
Old Oct 29, 2003 | 06:19 PM
NVetro's Avatar
I have both (manual fan switch, and a tune for 160 t-stat) I can honestly say I dont use the fan switch anymore, well unless I am at the track or its CRAZY hot out, the tune along doesn't let the temp go over 1/4 (180?) Both are cool to have though
Old Oct 29, 2003 | 06:38 PM
Dannno's Avatar
I'm right with ya...just bought a 97 Z28 and just put the SLP CAI on it. Mine came with great installation instuctions including pictures. Was a piece of cake, only took about 45 mins. Hell, took longer to get the filters put on than it did to install the intake. You'll see....
Old Oct 29, 2003 | 07:12 PM
It took me about 1hr 45min for me to do it. But i did it at night with a flashlight. The filters were the hardest thing to get on with that little of space to tighten them down.
Old Oct 29, 2003 | 07:19 PM
Transamdriver's Avatar
I just stuck the filters on my SLP intake and jammed them through the hole. They got squished a tiny bit, but it was worth it since Im no keeping in very long in favor of "other things".
Old Oct 29, 2003 | 07:46 PM
1msfyter's Avatar
Install Very easy. Where the CAI holds down behind headlights might need to be bent a bit. Install the filters AFTER the CAI is installed. I also cut a square C in the underside splash guard to form a small air scoop.It can be pushed back up if needed.
last month
http://www.bealer.org/enginec.jpg
last week-added a few more things
http://www.bealer.org/bling4.jpg
Old Oct 29, 2003 | 08:08 PM
b-stevens's Avatar
1msfyter, that is one clean engine compartment. Is there any advantage over having two filters on the SLP compared to having one on the K&N? I've been wondering about the airflow coming from two tubes rather than one, wouldnt the suction be less branching out into two tubes with two filters on it than it would be with just one larger filter?
what did you use to clean it?
Old Oct 29, 2003 | 08:21 PM
Onyx LT1's Avatar
I've also been wanting to which is better, K&N or SLP. Albeit the HP difference between the two would be unnoticeable, I'd still like to know.
Old Oct 29, 2003 | 09:42 PM
Seal's Avatar
sounds just like what i did
Old Oct 30, 2003 | 07:50 PM
SLP cold air
thanks for the advice, i was wondering if anyone could show me a pic of what its going to look like after im done under the car, i took the stock air filter and everything off but when i got to the splash guard it is still conected sould i cut it off or screw it back on then set a hole??? also i didnt bleed my thermo, but how do u do that? i started my car up without bleeding it that wont hurt it right? and this kid that i brought this slp cai said that i might need a "recharge kit" for the filters how do i go about that or can i clean them out or just buy new ones? sorry for so many ?'s just trying to learn.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
C6LS3
Apr 15, 2015 09:50 AM
QuickSilver02
Apr 7, 2015 11:12 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
BM93Z
Aug 22, 2002 02:45 PM
