SLP Clutch...Clutch Chatter??
Old Jul 6, 2003 | 09:50 PM
greg0101's Avatar
Ive been researching clutches for a few days now and i think that im going with the SLP clutch disk, PP, and TO bearing...is that all i need?
From what i here this is the most reliable, better than stock, clutch for a midly modded car? Is this true
Ive been reading about problems with Clutch Chatter with an LT4 disk? I dont get what this is talking about? Will i have this problem with my car? I plan on keeping the stock flywheel.
Thanks,
Greg
Old Jul 6, 2003 | 09:57 PM
dynomight's Avatar
I think the chatter youre referring to is the throwout bearing chatter prevalent on many of our cars. I am way past that point with my car, but i did have the SLP clutch setup before i went spec3. I had the chatter before, and after the install of the SLP setup. Could possibly be a pilot bearing also. Plan on changing that anyway during the swap. Good luck
Old Jul 7, 2003 | 12:36 AM
96LT14u2Nv's Avatar
i didnt have any problems with clutch disk chatter when i used that clutch. that is what i liked about it. more than likely the noise will come from the throwout bearing. u shouldnt get too much noise though, u will like that clutch for a mild street car!
Old Jul 8, 2003 | 03:44 AM
HungryT/A's Avatar
Have you resurfaced your flywheel?
Clutches can chatter when the FW is not perfectly smooth.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
