Slower ET Without Air Filter????
Old Aug 15, 2010 | 06:22 PM
Mystery Bird's Avatar
I made six passes at the track, on the second and fifth pass I pulled the air filter out to experiment, both times netted the slowest times of the day. Has anyone else observed this? or have an explanation why it would be slower?
Old Aug 15, 2010 | 10:21 PM
knta4dnu's Avatar
Question
I'll take an educated guess. I believe the computer tries to make adjustments but didn't have enough "learn" time to adjust for the less restricted flow on those short passes.
Old Aug 16, 2010 | 12:41 AM
MikeGyver's Avatar
Are you sure you didn't suck in a bird?
Old Aug 16, 2010 | 05:14 AM
No. There's no "adjustment" to make. Removing the air filter should increase air flow very slightly. The increased air flow is directly measured by the MAF sensor, the PCM adds the required amount of fuel.
With the LS1 style hood/air box, the air filter may be providing a smoothing of the flow, reducing the turbulence into the throttle body. Turbulence eats up pressure and reduces flow.
Old Aug 16, 2010 | 07:31 AM
I'm not using the hood for air flow. I'm getting air from the bottom with something similar to the SSRA kit except extended all the way to the spoiler under the front of the car.
Old Aug 16, 2010 | 09:40 AM
95z28onjuice's Avatar
is the MAF still on your car?
Old Aug 16, 2010 | 10:02 AM
Yes, it is stock untouched.
Old Aug 16, 2010 | 10:07 AM
Well i would think your times should be the same with or without a filter. tha is weired. less restriction more air more power but not always better times. but slowing down is not right at all. the pcm pull timing or fuel is what must be going on
Old Aug 16, 2010 | 11:13 AM
LT1PoloGreenSS's Avatar
Yep on my GTO we took the air filter out and it ran a 13.6 instead of the 13.0 it was always running
Old Aug 16, 2010 | 11:23 AM
NJ-LE's Avatar
We need numbers!!! "Freescan" these runs so we can see if the gms of air flow are different and/or the incoming air temp. Or if intake noise differences are affecting PCM retard.
Old Aug 17, 2010 | 04:46 PM
1badeagle's Avatar
I bet it has to do with the air filter missing causing turbulance in the air intake and actually slowing things down a bit.
Old Aug 18, 2010 | 01:42 PM
GRIDERMAN87's Avatar
wow...thats a big drop, thank you K&N
Old Aug 18, 2010 | 02:11 PM
JakeRobb's Avatar
Super Moderator
Immediately after making the dyno pull in my sig (325rwhp), I pulled out my air filter and made another pull, which was down 7hp. To rule out heat soak, I made a third pull which was right back to 325.
I've always wondered why, too. I assume that turbulence is the right answer.
Old Aug 18, 2010 | 04:47 PM
Procharged94Lt1's Avatar
Yes- we played around on a dyno one day also- did the same thing, 3 pulls back to back and the hp was down considerably after pulling the air-box. The boys at the dyno shop confirmed that the turbulance disrupted the air-flow into the MAF and thus the car made less power.
I would say that there is plenty of evidence here to support it as well.
Old Aug 19, 2010 | 07:34 AM
Everyone thank you for sharing what you observed too. I'm glad it's not just my car.
