Slow starting. Voltage gauge too low? HELP
Old Aug 12, 2006 | 03:01 PM
Bamfer9duce's Avatar
Okay so before I was trying to trouble shoot problems with my car. It has a sluggish start to it sometimes. I did the fuel pressure check, checked the fuel pressure regulator, and picked the rail up and checked for leaky injectors. Now here is what happens when I go to crank the car and get it started. When you move the key to accessory the gauge on the dash moves to the very top of the red section. I guess that puts it at about 11 or 12 volts. Then when you are crankin it drops down deep into the red just a bit over the 8 or almost down to it. Once started the voltage jumps up where it should be at like 15 or 16. Is this kinda thing normal? I want my car to fire up right away. The only thing is I have no idea how to check grounds or even what they do so if somebody could explain that. Now I know its not my starter because I've had 3 different ones since I've had this problem. Also I know its not the battery because Autozone put it on a trickle charge and they said its perfect. Lastly my alternator is fairly new as in 1 year 1000 miles. Whoever can help please chime in.
Old Aug 13, 2006 | 10:26 PM
Re: Slow starting. Voltage gauge too low? HELP
Helllo?
Old Aug 15, 2006 | 03:39 PM
Anybody?
Old Aug 15, 2006 | 03:57 PM
lneemup's Avatar
Cranking voltage should be 10 volts or more. Replace the battery and make sure your alternator is charging.
Old Aug 15, 2006 | 04:41 PM
BrandonKeith's Avatar
I've been working on cars and in autoparts long enough to know a very important rule of thumb when it comes to electrical parts, especially alternators and starters.
Just because it's new, doesn't mean it's good.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
super83Z
Jul 21, 2002 02:43 PM
