slotting lifter bore's?
Old Oct 9, 2005 | 01:01 AM
amean94ta's Avatar
only answear if you know please
say a lt1 like mine was slotted now i hear it will cause high rpm bleed down since these motors are hyd, this motor shifts at 6450 is that effecting this motor and if it is would a solid roller swap fix this?
Old Oct 9, 2005 | 04:28 PM
amean94ta's Avatar
Re: slotting lifter bore's?
anyone need to help this guy out cause time is a issue
Old Oct 9, 2005 | 05:01 PM
1racerdude's Avatar
Ya mean slotted to oil the rollers? Don't understand where it's slotted.
Old Oct 9, 2005 | 10:24 PM
amean94ta's Avatar
the lifter bore you take a slotting tool and put a straight line the whole length it was a old school trick before hyd now i hear its bad on hyd. its a extra drain back to bleed off pressure and get more oil on the cam
Old Oct 9, 2005 | 11:04 PM
SStrokerAce's Avatar
Yeah you don't need to do that on a roller cammed motor at all.... do you have this done?
Bret
Old Oct 10, 2005 | 09:29 AM
amean94ta's Avatar
yeah i do its a shame cause i know better but my dumb *** cousin did it. from gaining knowledge over the years everyone i used to look to i look down at now...... anyways going solid will fix this right? I did not see any side effects from this that i could tell but i was thinking of going solid anyway plus they have that oil problem that this might help
Old Oct 10, 2005 | 11:44 AM
1racerdude's Avatar
It's alright to do it on a solid roller,but not all the way up. It goes from the oil hole in the block down toward the cam.It was used to oil the rollers on the lifters and the cam. Wasn't anything about bleeding any pressure.
Crower and Isky now have mech rollers that are pressure lubed and ya don't have to do it.
Going solid or putting bushings in the block will fix it. Me I would bush it if they are all the way up the full length of the lifter bore, cause that's not the proper way
Old Oct 10, 2005 | 11:59 AM
OldSStroker's Avatar
Sounds like a good idea. Around here that's something like a $600 job to get it done right. Probably a lot more $ than it cost to slot them.
Old Oct 10, 2005 | 12:59 PM
1racerdude's Avatar
Another thought-- they make mech lifter's with larger bodies than SBC size. Ya could have the the lifter bores bored to MOPAR size and get the bigger lifter's.
If ya don't have a bunch of money tied up in the block,I would get another one vs oil spraying all over the lifter valley.
Old Oct 10, 2005 | 01:20 PM
amean94ta's Avatar
well i was also thinking about going with the mopar lifters anyway along time ago it is my spare motor (another 396) i was gonna swap it out and work on the 396 i ran this year but maybe not
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
heus
Sep 8, 2015 12:01 PM
