Sloppy steering
Old Oct 14, 2003 | 04:19 PM
MadMaxz28's Avatar
Sloppy steering
hey guys just wanted to know if i need a new rack and pinion or not. when crusing i can turn the wheel 3" right or left from center before the wheels will start turning. hard to keep car in straight line when on highway. wants to drift. would this be the worn out rag joint? i read this when searching
http://www.unbalancedengineering.com/Camaro/
"Rag Joint Eliminator (1993-1997)
Eliminates the factory rubber-fiber rag joint which can degrade and introduce steering slop. This is especially true on cars with the additional heat generated by headers. The kit includes a CNC machined coupler made from 6061-T6 aluminum which is then anodized black for corrosion resistance, and four grade 8 fasteners. A set of detailed installation instructions is also included. Cost $32 "
Old Oct 14, 2003 | 04:24 PM
joeSS97's Avatar
It could be any of these.Rag joint,ball joints,tie rod ends.Or a combination of them
Old Oct 14, 2003 | 05:05 PM
MadMaxz28's Avatar
it had an alignment a month ago after i put new rod ends on. guess that leaves the rag joint
Old Oct 14, 2003 | 10:30 PM
94Sleeper's Avatar
I had a very similar problem. I also had a lot of slop in my steering wheel. The Rag Joint Eliminator kit worked great. Easy to install and I would recomend it to anyone with headers. The problem stems from the headers cooking the rag joint causing it too become too soft.
Old Oct 15, 2003 | 08:12 AM
Joe K. 96 Zeee!!'s Avatar
How are the instructions that come with it? How long does the install take? Any special tools required?
Old Oct 15, 2003 | 09:21 AM
ishz28's Avatar
I was looking at that as well. How hard would it be to drill the rivets out of the Rag joint?
Old Oct 15, 2003 | 10:20 AM
96 WS6's Avatar
3 INCHES!!!! Damn man... I have the rag joint elim and it's a good piece but be warned, you better have some nice tools to drill those rivots out because they were some of the biggest pain in the asses I have ever had to experienced.
Old Oct 15, 2003 | 06:09 PM
ishz28's Avatar
Thanks for the info about the rivets. To the machine shop it goes.
Old Oct 15, 2003 | 07:16 PM
Hyperspeed97z28's Avatar
Thanks for the info on this piece to fix it and a link, I just bought one, I cant wait for it to get here, I know its gonna help with my steering slop!
HibachiZ28
Nov 6, 2015 12:53 AM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
Aug 7, 2015 01:26 PM
