slightly glowing headers during break in questions..
Old Dec 21, 2006 | 07:26 PM
  #16
SS RRR's Avatar
i think what some of you are missing is the fact he observed his headers glow slightly in the dark. i highly doubt there's any kind of problem.
Old Dec 22, 2006 | 08:04 PM
  #17
97bowtie's Avatar
Originally Posted by Lonnie Pavtis
An overly rich mixture will not be hotter.... rich mixtures will burn slower & often burn into the exhaust causing glowing headers. This directly relates to the retarded timing issue as a rich mixture will require more advance to prevent this.
Fact is, that as you lean the car (from say 12:1) it will cause a hotter burn as the mixture leans out towards stoich. Deping on the actual engine configuration, peak temps are somewhere in the mid14:1 range. Go leaner & it will then start to cause an additional drop in temp as well.
This is why most cars stay at 13:1 or richer to prevent engine damage under full throttle. Thats why they say lean is mean. It will generally run the best on the verge of damage.
Get an EGT & wideband, the results are very factual.
I never said a rich condition would cause a hotter burn, of course it won't...I said it will cause the headers to glow. This is caused by the excess fuel igniting in the header primaries causing them to glow, which can also be caused by retarded timing. I'm agreeing with what you are saying.
Old Dec 22, 2006 | 08:06 PM
  #18
97bowtie's Avatar
This isn't necessarily true. My car ran terribly when my crank reference angle was off and the headers would glow bright red in the dark, but you couldn't see any glowing during the day.
Old Dec 22, 2006 | 09:18 PM
  #19
mobleman's Avatar
Noted, but as I mentioned, in my case it was a very dull glow.. not bright at all.
Great info from all on this thread!
Old Dec 22, 2006 | 11:50 PM
  #20
mdacton's Avatar
stand at the end of the track at night and look at peoples brakes
ive seen plug wires glow at night also....not mis fire but the whole plugwire glow a light blue
I once had headers look like that on a 305 at 8500 rpm
Old Dec 23, 2006 | 09:47 AM
  #21
97bowtie's Avatar
You're talking about the headers glowing at idle and at 2k rpm under no load. They shouldn't be glowing at all under those circumstances IMO. My guess is you are running pretty rich from that tune and/or not running enough timing. Hope everything is fine.
blkWidow
Sep 6, 2015 05:17 PM
Critter
Jul 7, 2015 08:33 PM
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
