Slight idle problem after Hot Cam install.
Old May 8, 2003 | 07:30 AM
jpolz's Avatar
Ever since I finished my hot cam install I've had a slight idle problem. It only happens at idle while in gear (A4). The RPM's just kinda bounce between 600 and 800. It's almost like the PCM is trying to make it idle at 600, but the cam wants to idle at 800. Is this just the way it is with this cam, or is this something that's corrected with a re-program, or do I have a valve that is maybe a little too tight? Any suggestions?
Old May 8, 2003 | 07:35 AM
Ken95Z28's Avatar
You will have to get it reprogamed than you should be fine. The idle should be bumped up a little up around 900-1000.
Noenav
Mar 1, 2019 07:38 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
edman
Jan 22, 2015 02:45 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
