skip shift help!!!!!!
Old Jun 3, 2005 | 09:36 PM
hughett17's Avatar
is there any way u can get the "skip ship" effect with out actually buying the skip shift part i seen some thing on a web site and it said u can disconect something from the computer and it is the same and buying the lil deal for 30 dollars if anyone knows please help me.....
Old Jun 3, 2005 | 09:47 PM
Bow94z's Avatar
Re: skip shift help!!!!!!
2.2K Ω 1/2 watt resistor you can get a pack of 5 at radio shack for like a 1$
http://www.installuniversity.com/ins...sity/index.htm
go there and go under install documents on the left hand side, then scroll down and look under transmission "radio shack resistor" it shows you how to install it...its really easy and it works
Old Jun 3, 2005 | 10:40 PM
What year is your car? (Might want to add a "signature" with year, tranny type and any major mods - helps people give you the correct answer.)
For the 94/95 OBD-I cars, all you need to do is unplug the harness connector from the skip-shift solenoid. It will set DTC 84 in the PCM, but it will not turn on the SES light.
96/97 OBD-II cars, you will get an SES light when you unplug the connector, so you need the 50-cent Radio Shack resistor.
http://cjcfo.fbody.com/members/injun...E/T56Conns.jpg
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
