Single Plane pics>>>>
Old Jul 20, 2006 | 09:36 AM
fast 93 z's Avatar
For those who have not seen them yet. Here ya go....
http://www.ls1tech.com/forums/showth...5205241&conly=
Tony
Old Jul 20, 2006 | 09:41 AM
Colin91Z's Avatar
Re: Single Plane pics>>>>
Old Jul 20, 2006 | 09:50 AM
6SpdLT1Z's Avatar
Nice.
Old Jul 20, 2006 | 09:53 AM
Bow94z's Avatar
Old Jul 20, 2006 | 05:18 PM
fast 93 z's Avatar
Thanks guys!
Old Jul 21, 2006 | 07:28 AM
S M R's Avatar
looking good.
Lemme know when you are heading to the dyno. I'll bring mine down there too
Old Jul 21, 2006 | 10:10 AM
SLeePer350's Avatar
Couple questions which I am sure have been answered elsewhere, but so be it...
How's hood clearance with this setup?
What kind of power gains to you expect over a stock and/or ported LT1 manifold?
Also, what tuning is involved to get the car to run on this setup? For example, Accufab throttle bodies rotate the opposite direction and involve some clever wiring/programming if I recall to get them to run right. Is it the same or easier with this setup?
THANKS!! PICS LOOK SICKKK btw
Old Jul 22, 2006 | 08:30 AM
fast 93 z's Avatar
It clears an SS hood with minor clearancing.
Power gains with this intake over the stock are about 50 rwhp.
If you do not have a FAST XFI or standalone management system......do not get the Accufab 90 mm T-body. The tip-in part throttle tuning is almost impossible with the stock PCM. Just use your 58mm with an elbow from www.intakeelbows.com if you retain the stock PCM.
Thanks man!
Matt..........I will let you know man!!
Old Jul 22, 2006 | 08:41 AM
user 647483's Avatar
Thanks man!
50RWHP? WOW.
I'd love to see the curves on your graph.
What RPM does your setup peak at?
Old Jul 22, 2006 | 09:06 AM
Honda Hunter's Avatar
Awesome. A very sick setup.
Old Jul 22, 2006 | 10:15 AM
Victory Racing's Avatar
What are the plans for a power adder?
Old Jul 22, 2006 | 09:54 PM
fast 93 z's Avatar
As you can see in the pics it has a NX plate in between the intake and elbow. I will be spraying max 400 shot. Mainly just a 300 shot. Not gonna hit the big one unless I need to. I have an FJO progressive controller as well and a Nitrous Outlet stand-alone fuel system for the nitrous.
Old Jul 22, 2006 | 10:48 PM
CrystalSS's Avatar
Looks very nice!! The red intake and w/p really set it off! I think you may have just sold me on a single plane conversion. I was thinking about using the edelbrock 29135 super victor for my application. I have a baby cam 230/236 in my impalaSS so the 2.6 sq. inch runner cross section should work well, and the runners look to be about 6" long. Not sure if there are any single plane impala's yet....maybe I will be the first.
I'm Sure this is old news but I am thinking there is another benefit to single plane's... cool down between runs. Without ice my LT1 manifold would still be super hot even an hour between runs......the single plane should be much quicker to cool!
Hope you hit the 8's
Old Jul 23, 2006 | 08:57 AM
Sorry I hadn't looked very close at the pics, just for a quick second. Sounds good with the nitrous. What are your ET goals? Shot at the 8's?
Good Luck either way.
Old Jul 23, 2006 | 12:29 PM
ponyackn's Avatar
Is that N/A gains? How would you describe the drivability on the street? Is it any different than the stock intake under normal driving? Thanks
RX Speed Works
Oct 1, 2015 10:19 PM
cmsmith
Sep 14, 2015 09:25 PM
Nickster 7
Aug 27, 2015 10:12 PM
cmsmith
Aug 17, 2015 06:50 PM
Slayer
Aug 17, 2015 03:55 PM
