Single Plane for LT4 ?
Old Jun 21, 2007 | 11:28 PM
  #16
chief455's Avatar
can you guys post some pics or put a write up in the tech section? you have my complete attention! This is very true building old school motors as well. Only recent high rise dual plane intakes can come close to matching a nice single plane in the mid - high rpm range.
Just - what does an average guy with average money try to get in a single plane to eliminate the LT1/LT4 intake from the top of our 383's with good heads and cams?
Old Jun 22, 2007 | 07:49 AM
  #17
rskrause's Avatar
Moderator
I don't have any pics, I would post them for you if I did. But you don't need pics. It's pretty obvious what to do when you have the parts in front of you. But you need some decent mechanical/techical skills to do it. If you are going to DIY, just get the parts and have at it. Some measuring and machining will be needed. Or pay someone to do it.
Rich
Old Jun 22, 2007 | 06:57 PM
  #18
1badasZ's Avatar
so did anyone find out how much it would be to convert an intake over? lol im interested too
Old Jun 22, 2007 | 07:01 PM
  #19
95ttoplt1's Avatar
any where from 300-1200 depending on who does it.
You can get them in the classifieds sections at times too.
There is alot of manifolds with the injector bungs in them out of the box now. You would just have to change the bolt pattern.
Old Jun 22, 2007 | 08:28 PM
  #20
thesoundandthefury's Avatar
I made a thread here recently asking if anyone had done a GMPP dual plane conversion. A guy who saw my thread here copied the pic I posted and made another thread asking the same question on LS1tech. In the process of that thread, I got some info from Aaron at intakeelbows.com about doing a conversion. This post contains his responses:
http://www.ls1tech.com/forums/showpo...4&postcount=13
Old Jun 23, 2007 | 09:57 AM
  #21
SStrokerAce's Avatar
$225 is cheap, I guess his labor rate is lower per hour. $350 is more like it. Problem is as mdacton says above it takes a lot to get the ports right on a manifold out of the box. I'm working on a CNC version so the work is quick and easy. I've had them ported by numerous head porters, Meaux, GTP etc... and the work that goes into porting intakes is very time consuming, believe me I know first hand.
Bret
Old Jun 23, 2007 | 10:01 AM
  #22
95ttoplt1's Avatar
Originally Posted by SStrokerAce
$225 is cheap, I guess his labor rate is lower per hour. Problem is as Mike says above it takes a lot to get the ports right out of the box. I'm working on a CNC version so the work is quick and easy.
Bret
That is the lowest I have heard. But most are in the 3-400 area. I have only heard of one person charging over 500. Not trying to start a fight just saying.
Old Jun 23, 2007 | 10:16 AM
  #23
rskrause's Avatar
Moderator
Sometimes you get what you pay for. Sometimes you don't. I am not sure what I mean by that, but I posted it anyway.
Rich
Old Jun 23, 2007 | 10:18 AM
  #24
95ttoplt1's Avatar
Rich
Sure I understand. I know what I paid for mine and I can't find anything wrong with it. Everywhere it has been everyone is very impressed with the work.
Maybe the higher priced out fit is doing some extra work. The prices I posted were from Injector bungs and rail aatchments and bolt hole relocating. Porting would be extra.
Old Jun 23, 2007 | 10:21 AM
  #25
$350 for converting one over to a LT1 and making sure it's straight and bolts up is the key. Obviously putting bungs in some manifolds takes extra time, plus the cost of the bungs.
Bret
Old Aug 18, 2007 | 01:31 PM
  #26
jakesz28's Avatar
Hopefully you didn't get mad I was trying to get more info.
I'm still considering a different intake for next year. With a stroker.
Old Mar 28, 2008 | 12:48 AM
  #27
93SS's Avatar
Converted Super Vic for LT1 heads.
What intake gasket are most people using when doing this installation ?
Old Mar 28, 2008 | 09:12 AM
  #28
mdacton's Avatar
do you really want to know?
a $3 roll of gasket paper....do you know how to make a gasket?
After I make em I reuse em too...silicone on both sides
Old Mar 28, 2008 | 09:45 AM
  #29
1badasZ's Avatar
Originally Posted by 95ttoplt1
If you are going to run converted SBC heads you can run a Vic-E off the shelf that already ahs the injector bungs in it.
who converts and how much is it to convert sbc heads? my brother has a nice set of dart aluminum race heads he aint doin nothing with lol. i know it probably aint cheap but was just curious.
Old Mar 28, 2008 | 05:23 PM
  #30
93SS's Avatar
Thanks Mdacton. I have seen people use cork sheets before. What thickness do you normally use.
