Single Cat and Y pipe Myth Destroyed
Old Jul 6, 2005 | 02:32 PM
Heatmaker's Avatar
Advanced Member
Destroyed indeed...
It was rumored that fitting a single Cat on theI section of an offroad Y-pipe would not work for emissions. The Origins of this rumor seemed to have spread from Thunderracing. I decided to engage upone this rumor and investigate for myself. I called thunderracing up and talked to one of thier techs. I asked about the set up, and they confirmed again, that it would not work, but little do they know I have proven the myth false... let it be known... you can use an off road Y pipe and a single cat.
The story:
I installed Jet hot hot Long tubes, ordered a Hooker Y pipe, 2 3inch cutouts, and a 3inch Dynatech Highflow cat running through a Borla XR-1. I cut the I section of the Y-pipe off and ground it down, I then had the Dynatech weleded in place of the removed section of pipe. With the little room and clearance... I added appx. 7 inches of pipe beween the Borla and the cat then kicked the rest of the pipe over the axle and out the rear.
Now I must admit that this 3 inch setup gets very hot... enough to melt the rear bumper and anything else in the way if not careful. I took the car to the DMV and waited in the lanes. Finally the day of judgement came. I rolled my car into the bay, and the State inspector proceeded to install the Smog sensor.... I sat there and waited patiently for the results... I was handed a piece of paper with my test data... and the vehicle passed without a hint of issues. With all the off road accessories... the car passed right on track. So after dealing with the issue first hand myself... I must say that the off road Y-pipe and cat set up works prefectly.
Old Jul 6, 2005 | 02:35 PM
buzz12586's Avatar
Re: Single Cat and Y pipe Myth Destroyed
Awesome. I have been asking this question for a while and never getting a straight answer. I will be using almost the exact same setup except after the y-pipe running it into my Hooker Catback.
Old Jul 6, 2005 | 02:41 PM
slowpoke96z28's Avatar
i think people were afraid that the cat wouldn't light off because its so far back. but with technology nowadays, you can do anything, i guess.
Old Jul 6, 2005 | 02:42 PM
Heatmaker's Avatar
Advanced Member
I'll put my car on a lift and get some pictures for refference. Location is everything.
Old Jul 6, 2005 | 03:16 PM
buzz12586's Avatar
Yea I would love to see some pics.
Old Jul 6, 2005 | 03:45 PM
ghillie's Avatar
I too would like to see some pics.
Old Jul 6, 2005 | 04:26 PM
jsetzer's Avatar
Great for the sniffer, but remember some people have to pass visual.
Or if you are in Oklahoma, well you know.
Old Jul 6, 2005 | 04:58 PM
buzz12586's Avatar
I just have to pass the sniffer cuz I know where to go.
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
May 21, 2015 01:04 PM
Pig Pen
Parts Wanted
Apr 30, 2015 08:41 AM
Joshs99BlackBeauty
Jul 27, 2002 04:22 PM
