single cat or dual??? HELP
Old Jun 22, 2003 | 09:46 AM
Ginobeatz2001's Avatar
ok.. i got a 1996 z28. i wanna by the borla catback system. i need to know how many cat it has.. when i looked under i saw one and there is another thing that looks like a cat but its smaller.. so i wasnt sure
i took it to a mechanic and he said trhere is one cast and one resinator.. so i guess that means my z28 has a sigle cat. but on borla's site it says that 93-95 has single cat which use one system and 95-97 are dual. so since mine is a 96 borla is sayin that i have 2 cat.. but i only see on my car.
so im confused which one to get. can someone help me with this? and tell me whats the part # for the borla exhaust that i need?
Thanx
Old Jun 22, 2003 | 10:02 AM
CamaroBoy96Z28's Avatar
Re: single cat or dual??? HELP
Thanx
Theres 2 cats. I have the same thing, 96 and borla. The part number is 1455 if I remember correctly but I suggest you confirm that. Driver side cat is RIGHT under the driver side exhaust manifold and the other is in plain view on the pass. side plus you have that hump in the floor panel for it.
Old Jun 22, 2003 | 10:03 AM
nateh's Avatar
The stock Y-pipe on the '96 is a dual cat setup. There is one under the passenger footwell and another directly after the manifold on the driver's side. It's canted at an angle, sloping away from the manifold. Your mechanic is misinformed. The differences in the Borla cat-back systems will be in the length of the intermediate pipe. The '96 Y-pipe extends further back than the '94-'95, so the intermediate pipe is different in order to bolt up correctly.
Old Jun 22, 2003 | 10:45 AM
so does this car have a resinator? or is that small thing just the cat? and should i get high flow cats or is it just waste of money?
Old Jun 22, 2003 | 12:05 PM
nateh's Avatar
If you are talking about the small elliptical can on the passenger side, it is one of the catalysts. In stock form, there is no resonator.
As for changing the cats out, with the positioning of the driver's side cat, it's very difficult to just swap. Random Tech makes a replacement y-pipe with high flow cats. If you want to go with shorty headers later, they will bolt right to the y-pipe. There are lots of options if you want to change to a longer header, some involving more modification than others. The cat-back is a good route to go for. You'll see an improvement.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Jlo
Jul 29, 2015 03:52 PM
Catmaigne
Jul 14, 2015 05:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
camaro02DK
Jul 5, 2015 09:04 AM
