simple question about an oil change
Old Nov 18, 2003 | 02:57 PM
Haskin Z28's Avatar
not too worried but i was wondering, its only been about 2500 miles since my last oil change but its been about 4 months, however i am extremely, and i do mean extremely tight on cash, should i be fine for another month or so
Old Nov 18, 2003 | 03:02 PM
will62085's Avatar
if your doing mostly highway driving your fine, just watch the oil level
Old Nov 18, 2003 | 03:04 PM
Patman's Avatar
Re: simple question about an oil change
Yes, you'll be fine.
What oil are you running? (even if it's conventional, you'll still be ok though)
Old Nov 18, 2003 | 03:07 PM
z28s's Avatar
You should be fine, I just left my job where i was a quick lube manager, i saw cars that went 6000miles to 18,000miles on an oil change...(dont ask what happened to that engine), anyways dont make it a habit to go over on an oil change, but if you have to you have too. before your next oil change add half a quart or trans fluid to the oil and run it for 20 minutes or so then change the oil...trans fluid is a great and safe engine flush....
Tony
Old Nov 18, 2003 | 03:28 PM
tend2609's Avatar
not to be a pain in the butt, but go look around your house and get change then go to a coin star, i have found $60 this way. Then go to wal-mart and buy a Supertech oil filter and some Supertech oil, it i ill cost you 4.88 for the oil and 1.99 for the filter, that is what $7, and then just change your oil in a month or so when you have the money. Clean oil is better oil, no matter what kind it is.
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
SLIMJIM
Jan 7, 2003 11:06 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
