Simple Question....
Old Nov 29, 2006 | 08:52 AM
  #16
Sparkz28ss's Avatar
so if you lay into it...it will hold 40psi all the way up to say 5500 or 6000 rpms?
Old Nov 29, 2006 | 08:57 AM
  #17
popo8's Avatar
yeah... maybe a bit higher... it does rise from the 20psi at idle.... but maxes around 60 right b4 shifts... I think. Its my girls car so I dont beat it ....too often
Old Nov 29, 2006 | 09:06 AM
  #18
Sparkz28ss's Avatar
that just does not sound like a pick up tube problem to me,it sounds like its a little low...maybe a half quart,I would start there,better then doing all that work to pull the pan
for what its worth...I have had a pick up tube come off the pump in my Lt1...the oil pressure jumps around at idle around and pressure falls off with a rise in RPM
Old Nov 29, 2006 | 09:29 AM
  #19
Sweetred95ta's Avatar
If you have good oil pressure at WOT, right before the shift points, then your pickup tube is still attached. The car would be starving for oil by that point if that was the case. Maybe it is reading full, but you could try adding a 1/2 a quart of oil and see if the problem gets better. The only thing that you MAY see if you drop the pan is that the pickup could stand to be moved a little closer to the bottom of the pan.
Old Nov 29, 2006 | 09:31 AM
  #20
popo8's Avatar
Keep the ideas comming guy... I got the lift for tomorrow. i appreciate all the help...
Old Nov 30, 2006 | 02:36 AM
  #21
quulbreeze's Avatar
hey y'all i'm new here but i can't seem to get a good answer to that same question. i have 1994 Z28 A4 with 130K. at start up the oil pressure psi is around 55 and at warm idle about 19-20psi. the thing that gets me is that in park if i rev it up it goes to about 50-58 psi at 4000 rpm but at WOT it goes a tad over 40 psi at the same rpm. is that normal? i thought it's least got to 50 maybe 60 psi.
until the engines fully warmed it will go over that 40 psi mark though while driving. any advice or assurance?
thanks
Old Nov 30, 2006 | 03:27 AM
  #22
SS RRR's Avatar
You will get mixed answers to this reply only because I think everybody's guage readings vary. Perhaps it's the sending unit.. I dunno... My car has done that since new. Even after I refreshened the bottom end w/ new bearings it did that. I examined the originals with that thought in mind and they were all in perfect condition. I don't much worry about it anymore since my engine sees redline on a regular basis.
One explanation I've received is that when there's load on the rotating assy. (ie WOT going through the gears) there is pressure on the crank making it more challenging for oil to flow through its channels causing a delayed pressure reading. Dunno if that holds any truth however.
Old Nov 30, 2006 | 10:35 PM
  #23
popo8's Avatar
ok.... wanted to thank everyone for their help in solving this problem. Whether posting a response, or sending me PM's, I took ur advice. I got the car on the lift drained the oil, and used my fist to pound on the pan.... Low and Behold... I heard something bouncing. I undid the motor mounts, dropped th exhaust, loosened all the bolts on the K-Member, pulled the pan...and there was my pu-tube sitting in the bottom. Just wanted to say thankyou Again. She's good as new.
Old Nov 30, 2006 | 11:53 PM
  #24
Max 93's Avatar
glad to see you got it fixed.
Old Dec 1, 2006 | 12:14 AM
  #25
popo8's Avatar
Originally Posted by Max 93
the pickup tube fell off the oil pump. remove pan and weld on the tube.
Thanks... u were the first to suggest the p/u tube.....
Old Dec 1, 2006 | 10:19 AM
  #26
Sparkz28ss's Avatar
...good deal.
an easy fix is always good
Old Dec 1, 2006 | 04:14 PM
  #27
Dave89IROC's Avatar
how did you reinstall it?
I hope it is now bolted or welded on
Old Dec 1, 2006 | 04:26 PM
  #28
popo8's Avatar
3 good tacks.... it aint going nowhere....
Old Dec 1, 2006 | 04:57 PM
  #29
Dave89IROC's Avatar
HAWG
Sep 25, 2015 11:41 AM
Sep 17, 2015 11:53 AM
colts0455
Sep 11, 2015 06:16 PM
Latronaxe
Jul 20, 2015 12:00 PM
