signs of blown head gaskets?
Old Jun 26, 2004 | 06:54 PM
crAzy95z28's Avatar
please let me know...cause hopefully i dont have 2 blown head gaskets!!!
ill will take some pics here in a bit, but if you could please tell me the signs of them...
randy
Old Jun 26, 2004 | 08:06 PM
crAzy95z28's Avatar
have pics now.......
also found out my car has been wrecked with frame damage and it was fixed...but the car feels fine, but i am still mad at the same time http://community.webshots.com/album/97532348ltzpHf
they should be the last 3...but let me know assap
thanks
randy
Old Jun 26, 2004 | 08:10 PM
crAzy95z28's Avatar
might take up to 15 min to upload...but they should be there soon....
Old Jun 26, 2004 | 08:28 PM
Larry95Z28's Avatar
Well more than likely you will have white smoke coming out the tail pipes and it usually has a "sweet" smell to it. You could also have some overheating problems, loosing coolant or your oil might be a milky color. You may have one or all of these signs. Mine only had the smoke out the pipes one, I caught it early though.
Old Jun 26, 2004 | 08:34 PM
crAzy95z28's Avatar
no smoke commin gout..no overheating, but i had my gf drive it a while ago and she didnt know about the manual fan switch and it overheated and started spraying out coolant..and this was about 4-5 weeks ago maybe more...you think that coulda caused the heads to barley warp? but soon as it overheated she turned it off...and parked it and let it sit for a good 3 hours...then i had to come get it.....
but im about to have it checked out by a guy i kow who lives down the street..also my oil i think is like 1 1/2 qrts low
so no wi have to go get oil...
randy
Old Jun 26, 2004 | 09:13 PM
Larry95Z28's Avatar
With overheating it is possible to warp or even crack heads. You can have somebody do a leak down check and that might get you going in the right direction
Old Jun 27, 2004 | 01:05 AM
1racerdude's Avatar
Do a compression test.That will tell you right quick.Also pressure check the cooling system.
Old Jun 27, 2004 | 01:14 AM
944v8inDFW's Avatar
By looking at the picture the oil staining around the head / block mating surfaces are pretty normal for a higher mileage car. Oil tends to follow those around if you spill it or valve covers leak a tiny bit. From the looks nothing unusual. If you follow a post i did earlier about an opti seal leak. I bougt a UV dye kit about $20 for the dye with light and glasses. You can put it in the oil and water and see if / where it is leaking. I see you are a Texan, if you are metro Ft Worth you can borrow my UV setup. Bets $20 I ever spent on a tool. If you do it. Do coolant first, then oil.
Old Jun 27, 2004 | 01:15 AM
944v8inDFW's Avatar
Sorry, i am a noob, i see you are Huston.
Old Jun 27, 2004 | 02:34 AM
crAzy95z28's Avatar
lol yea....well about 4-5 months ago i got my cam installed along with lifeters, springs, pushrods and surfaced heads and a smaller head gasket, new timing chain and seals and front cover gaskets...for some reason it looks like a front main seal leak again...i dont think it is i think it is just running down or something cause that stuff was only put on about 5 months ago..and im 1 1/2 qrts low on oil? wtf is with that?
randy
Old Jun 27, 2004 | 12:51 PM
944v8inDFW's Avatar
It may not be the crank seal, again UV kit dye does wonders. It may br opti and or WP seal. check a thread i started. I wont beat it to death but I installed the WP and opti seal wrong by using grease on the seal surfaces.
http://web.camaross.com/forums/showt...hreadid=274891
It may not be your ownly problem 1 quart in how many miles? After an over heat i ALWAYS change the oil. Part of the staining my be from overheat antifreeze as well.
Good Luck
Old Jun 27, 2004 | 01:53 PM
crAzy95z28's Avatar
i think it may be my dipstick tube bc there is oil all over my starter!!!
i had to customize it to put in the LT headers a while back...maybe it came out a lil bit..i ned to check it here pretty soon..
randy
Old Jun 27, 2004 | 02:14 PM
gb95zconv's Avatar
I couldnt tell if you had a blown gasket from the pics , but I would like to schedule a car wash
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
