Signal Light Don't Flash at all!!!
Old May 27, 2003 | 04:57 PM
InGodITrust's Avatar
I had my ignition switch and wiring harness replaced today and now my signal lights don't signal. The driving lights all come on and the four-ways flash like usual. But the signal lights will not flash and the green arrow lights inside do not come on either except when the four-ways are on!! Does anyone have any ideas as to what the problem is????
Thanks!!
Old May 27, 2003 | 06:54 PM
ChickenScreamer94's Avatar
you say you *had* them replaced-so i.e. you had someone do them? If you did take it back and tell to fix it! If you did it then double check?
Old May 27, 2003 | 07:13 PM
Perhaps they disconnected the flasher. Also, there is a long connector attached to the right side of the bottom of the column-it might not be plugged in well (it can kinda bend and not get fully connected).
Old May 31, 2003 | 10:56 AM
Ok, I replaced my flasher and my signals still don't work! If my fourways work and my daytime driving lights work, could it still be a faulty bulb??? This is driving me nuts!!!
Old May 31, 2003 | 12:12 PM
z28jaz's Avatar
I would definately check the bulbs. Both times I had problems like that one of the rear bulbs had burnt out.
Old May 31, 2003 | 12:45 PM
Black_Z28's Avatar
Yeah, I would check your bulbs to see if any are blown.
DirtyDaveW
Dec 1, 2016 05:37 PM
stangspank
Nov 13, 2015 01:02 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jul 4, 2005 05:00 PM
