Signal Light Don't Flash at all!!!
I had my ignition switch and wiring harness replaced today and now my signal lights don't signal. The driving lights all come on and the four-ways flash like usual. But the signal lights will not flash and the green arrow lights inside do not come on either except when the four-ways are on!! Does anyone have any ideas as to what the problem is????
Thanks!! |
you say you *had* them replaced-so i.e. you had someone do them? If you did take it back and tell to fix it! If you did it then double check?
Perhaps they disconnected the flasher. Also, there is a long connector attached to the right side of the bottom of the column-it might not be plugged in well (it can kinda bend and not get fully connected).
Ok, I replaced my flasher and my signals still don't work! If my fourways work and my daytime driving lights work, could it still be a faulty bulb??? This is driving me nuts!!!
:mad: |
I would definately check the bulbs. Both times I had problems like that one of the rear bulbs had burnt out.
Yeah, I would check your bulbs to see if any are blown.
