Shutting off?
Old May 9, 2009 | 06:21 AM
  #16
What code(s) did you find when you scanned it? The only code that would relate directly to the coil would be something like DTC 42... but that code can also be the IC Module, the wiring or the Opti. There's a fairly complex diagnostic logic tree in the factory manual that walks you through a system check.
Old May 10, 2009 | 06:55 PM
  #17
ajenks_32's Avatar
i'm not sure what the codes were, I don't have the computer the shop ran on the computer said it was the coil, after we already put a new one on, then charge 400 dollars, and that wasn't the problem, i'm pretty pissed about that, anyways, changed the wire from the distributor to up top, not sure what it is called, but was told they get heat cracks on them, the wire is all the way on, now isn't starting at all. i have asoutley NO CLUE what to do!
Old May 10, 2009 | 07:22 PM
  #18
bubba4's Avatar
If it was my car I would'nt keep throwing parts at it. I would follow Injuneer's advice.
Old May 10, 2009 | 08:57 PM
  #19
ajenks_32's Avatar
yeah that would be the smart thing to do.
Old May 10, 2009 | 11:08 PM
  #20
If you paid someone $400 to diagnose your car, your are fully entitled to receive the results of that diagnosis, including the exact codes. You don't have to bend over for these shops
Old May 11, 2009 | 10:53 AM
  #21
ajenks_32's Avatar
i will get them tomorrow
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
KYWes
Sep 26, 2015 08:49 AM
Greg88
Sep 20, 2015 07:14 PM
