shredded belt
Old Jun 11, 2005 | 04:59 PM
95sr71's Avatar
shredded belt
I recently just put my motor back together and today I noticed that the accessory belt had shredded off 2 of the 6 ribs. I started dis assembly to determine the cause and noticed that alternator and the power steering pump do not line up with the ac compressor and crank hub. The alternator and power steering pump seem to be siting towards the back of the engine by about 2 ribs. Is there any spacers that go between the block and the accessory bracket? currently i have the bracket bolted directly to the block.
Jason Robb
Old Jun 11, 2005 | 09:37 PM
95sr71's Avatar
Re: shredded belt
Found the problem. The hub for the harmonic balancer was not seated all the way.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
