should a stock windage tray fit with an aftrmarket crank
Old Jun 21, 2007 | 08:12 PM
tagz's Avatar
I just got my short block back from the machine shop. i went to put the windage tray on and it seems like it is going to hit the crank. should it do this? or am i doing somethign wrong
I wanted to stick with a stock oil pan because i need the room for my turbo piping to go under the engine.
Old Jun 21, 2007 | 08:14 PM
ulakovic22's Avatar
It should fit and not hit the crank, but your rod bolts might be another story.
Old Jun 21, 2007 | 08:17 PM
tagz's Avatar
hm i'm gunna posta picture. could it be my splayed 4 bolt main caps ? i'm using arp studs
Old Jun 21, 2007 | 08:43 PM
WS6T3RROR's Avatar
get longer milodon studs or have the machine shop make you an adapter so you can space it away from the crank as required. it may take you a couple of shots but its not too hard to zero in on a proper location. that is if you have a stroker. otherwise compare it with where the stock studs would have had it sitting and adjust its placement.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
adam85
Parts Wanted
Jan 1, 2015 02:24 PM
ddr698
Dec 31, 2014 09:16 AM
