Should i be using bigger injectors??
Old Jul 13, 2004 | 08:53 PM
sean1997ws6's Avatar
I have the mods in my sig and I am still using stock injectors.do i need to go to 30s?Is it hurting me by not delivering enough fuel?
Old Jul 13, 2004 | 09:34 PM
944v8inDFW's Avatar
If you are still on your stock injectors and starting to mod I would move up to 30's or 32's. Lots of good info if you do a search. Most people like the SVO 30's and price seems reasonable. I personally like the Acell 32's. Not big enough can for sure make your motor go lean. The theroy goes that there is no such thing as too big of injector. So for you 30-36 should be great depending of course on budget. Not giving the motor enough fuel is VERY bad. I would also do a PCM tune if you move up.
Old Jul 14, 2004 | 01:24 AM
Loadre's Avatar
It's hard to say without logging your car and seeing what the injector duty cycle is. You're probably close though. You can get used injectors for dirt cheap at corral.net and since PCMforless is already doing your tune you can just have him burn you another prog for the bigger injectors.
Brian
Old Jul 14, 2004 | 03:52 AM
stik6shift93's Avatar
you should be fine with stockers, if you go with some ported heads then i'd consider upgrading.
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
95craz28
11
Sep 12, 2015 07:47 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
