Should I use stage 8 bolts or not ?
Old Feb 19, 2008 | 09:24 AM
  #31
Pro_built7's Avatar
ya thats exactly the thing i mean they are really expensive for bolts i dont really want to spend 60$ on darn bolts you know ?
b/c my stock ones were not locking and WOW were those a PITA they were NEVER coming out on their own you know?
i wonder if the aluminum heads has anything to do with it.
Old Feb 19, 2008 | 09:54 AM
  #32
2000GTP's Avatar
The stock ones, I'm sure, had the advantage of being held in better by rust and corrosion. At least mine did.
Old Feb 19, 2008 | 10:01 AM
  #33
Dave1980's Avatar
I have used the locking spring wire type bolts from autozone before. They work good and are cheap.
I have also used the stage 8 bolts, and they are a pain to get on and off.
Old Feb 19, 2008 | 10:14 AM
  #34
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
When I removed my stock manifolds, a few of the bolts were actually loose. And I'm sure they had never been removed after leaving the assembly line.
Old Feb 19, 2008 | 11:18 AM
  #35
Pro_built7's Avatar
right ya, as did mine, but i'm assuming if i used non locks, they would also eventually lock in similarly correct ?
Old Feb 19, 2008 | 11:42 AM
  #36
2000GTP's Avatar
If they are stainless, I would have to assume they would not.
Old Feb 19, 2008 | 11:57 AM
  #37
ssbowtie1's Avatar
Everything has already been laid out for you. The question is whether YOU find value and have the extra $20-30 to spend.
Personally for me it was between the ARP stainless header bolts and the Stainless Steel Breslins.
The ARP bolts were ~$33 + $11 Summit S+H. Total would have been ~$44. I found a set of stainless steel Breslins on Ebay for $65. For me, I found value in spending an additional $20 to have bolts that I know will lock in place and I wouldn't have to mess with re-tightening them. To me, the $20-$30 extra is worth the peace of mind. Then again, its not worth it to everyone. If you don't want to spend the extra $$ and don't mind installing a nice set of ARP's and re-tightening them a few times, then just go that route.
Old Feb 19, 2008 | 12:14 PM
  #38
Pro_built7's Avatar
right exactly. thanks man
and thanks to everyone for your help !!!
Old Feb 19, 2008 | 12:27 PM
  #39
Pro_built7's Avatar
one other quick question: am i going to need o2 extensions for my lt's ?
Old Feb 19, 2008 | 12:40 PM
  #40
BTC's Avatar
BTC
I needed an O2 extension on the passenger side for my Kooks. I didn't need one for the driver's side. Depending upon what kind of headers you buy, that may not apply.
Old Feb 19, 2008 | 12:57 PM
  #41
2000GTP's Avatar
I ended up needing two, a couple of 12"ers.
Old Feb 19, 2008 | 01:59 PM
  #42
Javier97Z28's Avatar
Moderator
I bought Stage 8's back in 2000 when they were still all the rage and didn't end up using the stupid locks anyways...
So I still use 'em, but not for their intended purpose, they just work as a bolt for me now.
Old Feb 19, 2008 | 04:44 PM
  #43
Green96Z's Avatar
I needed O2 extensions for both on the passenger side, the header O2 and after-cat O2. But OBD2 is different than OBD1. Depends on what you have.
Old Feb 19, 2008 | 04:56 PM
  #44
Pro_built7's Avatar
obd 2 1996
Old Feb 19, 2008 | 04:57 PM
  #45
Pro_built7's Avatar
oh and i won't be running cats. just the 2 o2's in the collectors on my pacesetters
