should i up grade injectors??
Old Jan 13, 2004 | 07:01 PM
97SS0594's Avatar
i just ordered a custom ground cc306 and a set of long tubes, along w/ the rest of my mods in sig, will i need to upgrade my injectors??
Old Jan 13, 2004 | 07:16 PM
Josh-'04 GTO's Avatar
Assuming your nitrous kit is wet, the answer is no. But when you go with ported heads (along with the cam) you'll be closer to needing a bump up in injector size.
Old Jan 13, 2004 | 08:05 PM
RE AND CHERYL's Avatar
Cool
Are you replacing the springs???
The stock springs can't take the lift of that cam. Are you planning on porting the heads? The stock heads can't flow enough to do that cam justice. If your not porting the heads you would be better off with a CC305.
The stock injectors will be fine with the cam you plan, you will need to have the ECU reprogramed for the cam. Once you port the heads I would go with 36 lb injectors.
Old Jan 13, 2004 | 08:29 PM
97SS0594's Avatar
im gonna have them worked pretty soon here, just slowly gathering stuff then gonna give it to my head guy and tell him to go to town!
Old Jan 13, 2004 | 10:32 PM
S.J.S.'s Avatar
30lbers will more than do it for you when your heads are done. Other than that the stock ones can easily handle up to 400rwhp.
Old Jan 13, 2004 | 10:48 PM
QCKZ28's Avatar
madwolf maxed his stock injectors out at 340rwhp.....
it was in a thread a while back....
jesse
Old Jan 13, 2004 | 11:24 PM
S.J.S.'s Avatar
I found it and as you can see there are a lot of people also claim to be making over 400 with the stock injectors. Not saying he's wrong....Ion knows what he's talking about. I just figure why spend the extra 255 if its not needed just yet. Cause I doubt he's gonna be throwin 400 with what he's got. That is of course if his 125 shot is wet.
Old Jan 13, 2004 | 11:30 PM
QCKZ28's Avatar
another option:
buy a AFPR and set it at 58psi with your stock injectors, and have the injector constant programmed at 30lb.
trick the engine into thinking it has bigger injectors....
bryan at pcmforless recommended this to me.
thats what i did anyway, it is good enough to trap 115mph....
jesse
Old Jan 13, 2004 | 11:35 PM
S.J.S.'s Avatar
hey QCK....thats some nice a** trap speeds my man. What else you got in there?? If you can get a dead hook you probably can get into the 11's.
Old Jan 13, 2004 | 11:39 PM
QCKZ28's Avatar
lloyd elliot ported stock heads, Xe224/230, various bolt ons, raceweight 3540lbs.
hopefully this season i will run high 11's.
winter mods include:
changing headers to longtubes with true duals
58mm TB
42lb SVO injectors (over kill)
et streets
jesse
Old Jan 14, 2004 | 01:04 AM
97SS0594's Avatar
oops forgot to add my nitrous is a dry kit ( yup im a weenie) but you cant see any lines or the box.
Old Jan 14, 2004 | 01:19 AM
QCKZ28's Avatar
yes you will definately need to upgrade injectors.
you will also need colder spark plugs, you should upgrade your fuel pump to be safe.
my stock fuel pump died at 350rwhp you dont want that to happen when your sprayin......
try the N20 forum, they can help more.
jesse
Old Jan 14, 2004 | 09:27 AM
LT4POWR's Avatar
I agree
Old Jan 14, 2004 | 01:36 PM
mongse_1's Avatar
You'll definitely need bigger injectors w/ a dry kit. A wet kit will add fuel w/ a separate nozzle whereas a dry kit relies on the injectors to introduce additional fuel into the chamber. On a 150dry, I'd go at least 36# injector and probably bump the fuel pressur e into the 50s just to be safe.
Old Jan 14, 2004 | 05:21 PM
WhoomWhaatWhaah's Avatar
SLP has a great deal going on injectors right now
