Should I switch to synthetic oil?
Old Jan 29, 2004 | 03:47 PM
warwickbass's Avatar
In a '95 Z28 with 146K? If so, which viscocity rating? Thanks.
Old Jan 29, 2004 | 04:54 PM
ATMINF's Avatar
I would say yes. The type depends on the temp (outside)that you are going to be running. Normally I run a 10 weight but now that I am stationed up here in Wisconsin and the winter temps are normally in the single digits I went to the 0 weight. Good Luck. I also use Mobil 1.
Old Jan 29, 2004 | 05:17 PM
StoneRhino's Avatar
I've got a question... I'm running 15-40 (Delo 400) in my Lt1 with 101k. I know this is kind of a dumb question, but is this to viscous? I ask because I have what sounds like an intermittent ticking lifter.
Old Jan 29, 2004 | 05:25 PM
jasons93z's Avatar
yes, i run 10-30.
Old Jan 29, 2004 | 09:01 PM
LameRandomName's Avatar
I use 5w-30 Amsoil in my LT1.
Old Jan 31, 2004 | 11:55 PM
The Hammer's Avatar
In my opinion, the Delo400 15w-40 is probably one of the best non-synthetic oils you can run and is perfectly safe for your LT1. I really doubt it is causing any ticking.
Hammer
Old Feb 1, 2004 | 09:45 AM
m_morrison14's Avatar
My buddy had a 97 Z28, a4, he switched to synthetic when he had about 95k, and he started to have oil leaks everywhere after he switched. I dont know if this has happened to anybody else, just thought I would let you know.
rideordie
Nov 5, 2019 04:52 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Nickster 7
May 1, 2015 09:04 PM
alex5366
Apr 1, 2015 09:27 AM
