should i replace optispark . . .
Old Feb 7, 2009 | 08:01 PM
dallas63's Avatar
i have a 1996 camaro z28 with a 160,000 miles on it . i having a tuneup done and replacing the water pump . should i replace the optispark too . mechanic said i could just do cap , rotor , and plugs .
Old Feb 7, 2009 | 08:09 PM
jtarp's Avatar
If its running fine i wouldn't worry about it,but if you do, I'd go with a msd cap and rotor.
Old Feb 8, 2009 | 10:08 AM
sbs's Avatar
sbs
It would be false economy to just do cap+rotor. Doubly so since you are paying for labor.
Old Feb 8, 2009 | 10:11 AM
MARKTHOMASBRAND's Avatar
If you know it's the original optispark that's still on there after 160,000 miles then I would be thankful for it's good service and change the whole unit.While the waterpump is already off you may as well,just my opinion .
Regards,Mark.
Old Feb 8, 2009 | 10:13 AM
96capricemgr's Avatar
Replacing just the cap and rotor is fine. When is the last time you saw someone replace any other WHOLE distributor based on mileage?? They don't, they do a cap and rotor at tuneup time.
The opti gets bashed because people neglect it not because it is bad.
Old Feb 8, 2009 | 10:52 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Personally, I would replace the entire distributor if it's been on for 160K. My bearings were shot at just over 100K, but my car also sat for a long time.
Dark Zeiro
Mar 11, 2015 07:15 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
