should i replace optispark . . .
i have a 1996 camaro z28 with a 160,000 miles on it . i having a tuneup done and replacing the water pump . should i replace the optispark too . mechanic said i could just do cap , rotor , and plugs .
It would be false economy to just do cap+rotor. Doubly so since you are paying for labor.
.Regards,Mark.
Replacing just the cap and rotor is fine. When is the last time you saw someone replace any other WHOLE distributor based on mileage?? They don't, they do a cap and rotor at tuneup time.
The opti gets bashed because people neglect it not because it is bad.
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Personally, I would replace the entire distributor if it's been on for 160K. My bearings were shot at just over 100K, but my car also sat for a long time.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
