should I replace oil pump on 170,000mi LT1?
Old Aug 5, 2005 | 11:52 AM
mkent's Avatar
I've been helping work on the brother's 95 Formula and we pulled the oil pan off to replace the gasket. We were wondering if we should go ahead and install a new oil pump while the pan is off the engine. The oil pressure always seems a bit low to me. My Z28 holds the guage needle beyond the half way mark while his Formula stays a little below the half way mark while driving the car.
Also, if I need to replace it, is there anything I should be aware of or is it as simple as removing a couple bolts and removing the old one?
Old Aug 5, 2005 | 12:05 PM
crazydavez28's Avatar
Re: should I replace oil pump on 170,000mi LT1?
how did you lift up the engine to get the pan off
also what comes off the cam to drive the pump
Old Aug 5, 2005 | 01:23 PM
mattbailey's Avatar
I'd replace it while you have the pan off, they only cost around $30 and there easy to install.
Old Aug 5, 2005 | 03:14 PM
I definitely would replace the pump while the pan was off.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
