should i replace the bearings before h/c
Old Nov 21, 2004 | 10:01 AM
T/A Racer's Avatar
okay heres the deal,
head gasket has been out for the last 500 miles. very negligent and havent got it fixed because i thought it was the intake manifold gasket. but probably have burned a total of 3 quarts of antifreeze in that time. drained the oil and couldnt find any water in there. never even ran warm and never got low on antifreeze. well now that i know its head gaskets im going to fix it and figured id upgrade while in there(cc305, 1.6rr, springs). but after all these posts about bearing failure should i replace the crank bearings while im at it. have 105,000 miles and dont need the headache of bearings going out afterwards. but id rather not pull the engine if i dont have to. plus would just replacing the bearings give me the insurance, or would something else just fail.
sorry for the long post, id like to hear ideas
thanks
Old Nov 21, 2004 | 10:18 AM
Loadre's Avatar
Re: should i replace the bearings before h/c
You've got just as much chance, if not more, of the bearings going out if you swapped them than if you let them be. Just be **** as hell about being clean when you swap it. Be careful installing the cam and change the oil religiously after it gets running.
Old Nov 21, 2004 | 11:10 AM
T/A Racer's Avatar
okay i think thats probably the route ill go thanks for the help
andrew
carl.froehlich
Mar 13, 2015 12:38 AM
BPS
9
Mar 5, 2015 10:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
chuyz28
Nov 25, 2014 11:14 PM
