Should I re-use ARP rod bolts in 600rwtq car?
Old Jul 7, 2007 | 11:15 PM
blue's Avatar
They only have about 13,000 miles on them, and they are clearanced for the 396 so I would rather re-use them unless those who know what they're doing advise strongly against it.
And I don't have a part number but would 50 ft-lbs be about right?
Old Jul 8, 2007 | 09:17 PM
Severous01's Avatar
they're cheap compared to a new engine.
buy new ones if you can
Old Jul 9, 2007 | 09:15 PM
busta9876's Avatar
ARP says they can be reused as long as they have not been overstreached. This could happen by over torque at initial assembly, or high loads in operation. Only way to know if they are streached, would be to have measured them new...then measured again at tare down.
If in doubt, buy new ones. However, if they are pressed in rod bolts with nuts, I would think rods could be distorted, if cap screws, you should be fine changing.
As for torque spec, you need to find out what the part# was, or at least the thread size and pitch, and check on ARP's website. www.arp-bolts.com
depending on size, and type of lube used on the threads and under the nut can greatly change what torque spec to use.
Catmaigne
Dec 25, 2014 12:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
