MSD opti-spark - Difference between two models for 94?
Old Jul 9, 2007 | 08:19 PM
detroit1994z28's Avatar
I have a 94 camaro z28. My stock opti-spark currently went out on me. I'm looking to upgrade to a msd opti-spark. They have two models thow. A 94-96 late model camaro and a 92-94 early model with fresh air hoses. I was wondering what is the difference between the two. I wanted to order this opti-spark asap but I need to know which one I need. Summit and jegs did not help me answer this question. How can I tell if my opti-spark calls for the one with the fresh air hoses?? Does anyone have pictures between the two or something so I can compare my stock one to it. Or will either one work since there both for a 94 z28??
Old Jul 9, 2007 | 08:51 PM
Dawgz83944's Avatar
I bought the MSD, it works really well. The way you could tell which you have is check your intake elbow for a blue 90* vacuum tube going into the top of your boot. That should connect to your OPTI. If it's not there you have a nonvented opti. You could upgrade your cam and timing cover (I think thats all) and get the vented OPTI.
Old Jul 9, 2007 | 08:57 PM
96capricemgr's Avatar
The reason for the confusion is the b-bodies got vented optis in 94 where the Vette and f-body didn't get them till 95.
On the MSD IMO you should not use it unless you have a keyed hub, degreed damper and have fabricated a timing pointer to verify it's setting. Even then the added "features" are meaningless to all but the most advanced users.
Consider putting a MSD cap and rotor on a stock base, this is a very good solution for most of us.
93z383's Avatar
it has to do with the pin drive or shaft drive, its probably miss designated not sure if there was a mid year change from the shaft to pin drive.
Old Jul 9, 2007 | 09:35 PM
Dawgz83944's Avatar
I had to buy one because of my application. I bought 3 NEW OPTI's from the dealer and all three when the weather was above 98* and the car was at operating temp, when I would shut it off the car would not restart and would throw the opti failure CEL (I think high resolution failure). The MSD has been a much tougher distributer for my use. It's not perfect but it works and thats what I need especially as stupid as the LT1 distributer positioning is. The MSD also has 1 extra screw on top to seal better, so where the stock OPTI is 4 screws to hold the cover on the MSD is 5.
Old Jul 9, 2007 | 09:53 PM
mrmint69's Avatar
I had the non vented unit and the MDS pro billet is vented. The catalog showed the early one was vented and the later one was non vented so i hope they corrected it. Be sure to read carefully before you install as many have had them come apart and screw things up. There are tons of threads on here.
Fastbird93
Apr 9, 2016 07:01 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
Jul 4, 2005 05:00 PM
