Should I get stock replacement vavle seals? Or is there something better?
Old Nov 26, 2004 | 01:21 PM
94 CAMRO Z28's Avatar
I would imagine to some extent, there can't be a huge difference. Maybe there are some aftermarket seals that will last longer, but is there anything wrong with replacing mine with the stock replacement seals? Thanks
Aaron
Old Nov 26, 2004 | 07:39 PM
Fuels94TA's Avatar
Re: Should I get stock replacement vavle seals? Or is there something better?
I don't see why not, when I broken a couple of valve springs I needed to replace a couple of seal that I got from NAPA for 1.88 each. They seem to hold up very well, also I've heard the rubber seals are better then nylon/plastic type.
Old Nov 26, 2004 | 09:47 PM
Fbody1's Avatar
why are the rubber ones better? are the teflon seals ok for street use?
Old Nov 27, 2004 | 10:03 AM
arnie's Avatar
The seals to get for superior longevity and sealilng ability would be labeled as 'viton' valve stem seals. Consider them a high performance seal. Far superior to ordinary rubber seals. Teflon valve stem seals are not a good choice for street engines that see frequent use.
Old Nov 28, 2004 | 03:59 AM
unTAmedLS1's Avatar
And btw the viton seals are the ones that come with pretty much every gasket kit including the ones from GM
Old Nov 28, 2004 | 04:56 PM
marshall93z's Avatar
yeah, the felpro ones i got from advanced auto were "viton"...
Old Nov 29, 2004 | 12:29 AM
Yep just picked these up myself. They had to get them in but it took less than 24hrs. Picked them up today and I'll throw them on Mon. morning.
Aaron
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
GigaMp3z
Feb 20, 2003 02:57 PM
mjcent922
Jul 27, 2002 12:42 PM
