Should I get rid of my Flowmaster?
Old Aug 14, 2002 | 07:28 AM
brandboZ28's Avatar
Post Should I get rid of my Flowmaster?
It rattles pretty bad and its kinda embarrasing. I have heard that Flowmasters are very restictive anyways so I am looking to upgrade. A friend of mine with an 02 T/A just put what he calls a Dynomouth on his car and it sounds sweet. All the Dynomouth is, is a setup like the SLP Loudmouth but with a Dynomax Bullet muffler in the place of the loudmouth resonator. Its would be cheaper for me to do this custom setup so that why Im not just going with the Loudmouth itself. Has anyone done this on an LT1 and if so, how did it sound. I am also weighing my options because it I go to a custom setup, I will lose my cutout(it is custom made and cant be removed and repalced). I just need some help because running around on my rattly exhaust is killing me. Any info would be greatly appreciated and thanks in advance.
Bo
93 yellow Z28
Flowmaster w/cut-out, Hypertech chip, K&N, TB bypass, 160* t-stat, clear corners, SS 10-spokes
70 Olds 442 W-30(1 of 262) 455ci with 425hp.
http://community.webshots.com/user/brandboz28
Old Aug 14, 2002 | 07:37 AM
EviLBoX's Avatar
Post
You should try to figure out exactly what's ratttling on your catback. I had the same problem a while back and it turned out as the i-pipe goes over the axle it was hitting the heat shield and rattling. It was an easy fix.
I'm looking to replace my Flowmaster also, mainly because of the restriction. I don't want to have to use my cutout anymore, I want to get rid of that also. I've contemplated the Dynomouth also, but then again I'm afraid it might be too loud on my car.
1997 Bright Red Z28
A4, 3.23's, K&N FIPK, FLP Headers, Flowmaster, Cutout
My Z28
Old Aug 14, 2002 | 10:01 AM
Post
I don't think that you can just say all FlowMasters are restrictive. It depends on which one you have, the size, model etc. I have the Flow' in my Mufflex 4" system, and comparitive tests on the engine and chassis dyno have not shown any restrictions with the system. George Baxter's 97 30th SS convert (3,900#) ran 9.11 with the Flowmaster/Mufflex 4". I have a picture of it blowing a huge cloud of rust out the single outlet (he had his original "2-on-the-left" tips welded on the single 4" outlet) on the launch for the 9.11-second pass......
Fred
94 Formula A3+1: 381/TH400+OD/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Aug 14, 2002 | 10:42 AM
EviLBoX's Avatar
Post
Fred is right, sorry about that. I'm running the 80 series muffler and it has proven to be a restriction in my application at the track. I just wanted to clarify that.
1997 Bright Red Z28
My Z28
Old Aug 14, 2002 | 10:45 AM
97Z-M6's Avatar
Post
i dont like the flowmaster either so i have ordered a bullet from jegs to replace mine. i hope its better. i heard one on a 95z the other night and it sound good.
97 6 speed 4.10
gears,kevlar clutch,
ported maf, ram air,
tb bypass, 160 stat, fan switch mod, skip shift eliminator.
best time: 12.76 at 107 on kumho 712s
dont remember the 60ft time.
Old Aug 14, 2002 | 05:43 PM
brandboZ28's Avatar
Post
Well, I know its my muffler because I ran over a piece of tire from a blowout right in front of me and it bent up the muffler pretty good. I think it just knocked a weld loose and now it rattles. I just took my cat off so there is a good bit more flow going through the muffler thus, making it rattle. Anyways, I think I am going to go with the Dynomouth because it is cheap and sounds freakin sweet. I will be sure to let you know how everything turns out. THANKS!!!!
Bo
93 yellow Z28
Old Aug 14, 2002 | 06:11 PM
dablandman's Avatar
Exclamation
I am thinking about modifying my Loudmouth exhaust, i've heard that replacing the resonator with the bullet muffler quiets it down quite a bit and gets rid of the raspiness. I've had this setup for over a year now, and I'd like something quieter.
1995 ragtop Z28 A4, 3.23 gears, SLP loudmouth exhaust, Borla Y-pipe, homemade Air induction, 1.6 rockers, 160* thermo, TB coolant bypass, removed MAF screen
http://jonbland.freeservers.com/index.html
Old Aug 14, 2002 | 07:27 PM
Grease's Avatar
Post
I have the same problem as you, a rattling flowmaster cat-back, and its falling/rusting apart. I was planning on going with either a random-tech cat-back or an SLP loudmouth, however I think I'll go the cheap route and get a Borla XR1 muffler and just have 2 tailpipes on the left.
BTW, nice car, I've never seen a yellow Z28 and the SS rims make it look even better
Green 1995 Z28, 6-Speed
Best ET: 12.616 @ 110.33 mph, 1.869 60ft
Race weight: 3430lbs
Old Aug 15, 2002 | 03:47 PM
brandboZ28's Avatar
Post
Thanks for the kind words Grease. I have priced everything up and a complete Dynomouth setup is going to run me close to $130. I dont know if I am going to be able to beat that price. Anyways, I think I am also going to put the stock rectangle tips back on as well to give it a sleeper look.
Now, something I just thought of. Could the absence of my cat. converter be causing my exhaust to rattle? The reason I ask this is because the first time it rattled is the first time I drove the car after removing the cat. Just a thought. Anyways, thanks again for the help and kind words.
Bo
93 yellow Z28
Old Aug 15, 2002 | 05:47 PM
RedTransAm21's Avatar
Post
where are you getting this dynomouth setup? that sounds like a pretty good price. Thanks
Old Aug 15, 2002 | 05:48 PM
Beast96Z's Avatar
Post
Chunk it. I HATE FLOWMASTER.
96 Z m6- Extreme Comp Cam 230/236,Pro Performance Stage 3 Ported LT-1 heads 280 Int. 210 ex.@600,ported intake,mezier H2o, all bolt-ons. 397RWHP and 368RWTQ. 11.98@117.23
http://www.fbody.com/members/greenbeast
Old Aug 15, 2002 | 07:33 PM
brandboZ28's Avatar
Post
RedTransAm21, I am buying all the pieces and having my exhaust guy put it together for me. Napa carries the muffler for something like $40. I am not going to be going with a full catback, just my I-pipe and the bullet muffler welded in. Hopefully it goes together as good as my friend's did. I will be going to be putting it together early next week and I will be sure to let you know how it turns out.
Beast96Z-I'm chunkin it!
Bo
93 yellow Z28
Old Aug 15, 2002 | 07:41 PM
sc93's Avatar
Post
for what it's worth,
i have the Loudmouth on my 93 Z and with stock manifolds and catalytic it sounds absolutely amazing. It is the sound I've always wanted. Its deep and very loud, but mine does not crackle or pop at all. No raspiness. I love it, and its stainless steel which is very nice. I like it better than my old dynomax ultraflow muffler, and better than my friend's borla.
http://camaroz28.cardomain.com/id/sq4u2
AIM - So Slow V6
Old Aug 16, 2002 | 07:06 AM
brandboZ28's Avatar
Smile
Thanks Clubbin54. That makes me very happy. I cant wait to get that crappy Flowmaster off of there.
Bo
93 yellow Z28
Old Jan 31, 2003 | 03:15 PM
fozziez28's Avatar
Guys, keep in mind u need backpressure. The bullet does remove the raspiness of the loudmouth, however, it will most likely make it louder. For the guy in Ramona, Oklahoma. I dont know where that is. I live in Norman, Oklahoma. Performance muffler her in Norman is gonna do my whole setup for $115 including piping and muffler. I am putting b&b tips on mine. I am also goin with a random tech cat or carsound cat. I have headers so I will have no backpressure without the cat, which is a bad thing. Flowmaster 80 series is what I have right now. It is restrictive, but sounds good wot, until u get off and the popping begins. Good luck to you. If I can after I get my setup I'll try to put a video of it on here with sound clip. Thanks, Michael
