should I file these piston rings?
Old Nov 6, 2007 | 09:03 PM
Mean Green's Avatar
The shop who did the machine work also threw in a set of piston rings. they are speed pro plasma moly rings. They are the "standard gap" rings that they claim need no file fitting. I pulled out a couple and measured their gap. The top ring measures .016"-.018" and the second 0.19"-.020"
I plan on running a good amount of nitrous, 200-250 shot. I'm thinking the ring gap should be more in the area of .020-.022" for the top ring and .023-.025 for the second ring. Is it a problem to file these rings? I'd hate to throw away a free set of rings, but if they're not right for the motor, then so be it. How about the gap size too? too tight, too loose?
Old Nov 6, 2007 | 10:04 PM
1racerdude's Avatar
Get the thousands per inch of bore and file them.Usually 'bout .004 x the bore size and a little more for hose.
.020 isn't enough for NO2.
Call Speed Pro and get their recommendation.
realistyc
Jul 28, 2015 07:32 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
NewsBot
Jul 8, 2015 06:47 PM
