Should I buy these?
Old Aug 25, 2003 | 01:08 PM
AxeGrinder30thZ's Avatar
Should I buy these?
Found some LT1 ported heads for sale. Here's the specs.
Reverse cooled cast-iron professionally ported heads. 2.02 intake. 1.600 exhaust valves. Fully ported exhaust ports. Intake ports are slightly ported and shaped. 3 angle valve job, new seals, new double springs setup for hydraulic roller cam @ .550 lift. Standard retainers and keepers. Excellent shape. About 50 lbs. each.
The price is $600 but I think I can get them cheaper. Is this a bad or good deal? and How much could I sell my stock heads for?
Old Aug 25, 2003 | 01:55 PM
DR.ZED's Avatar
Re: Should I buy these?
The cast iron heads were the Impala/Fleetwood heads. They're not the aluminum f-body pieces. They'll weigh about 60 lbs heavier.
2.02 / 1.60 are large valves.
If the flow works, then iron heads would be the way to go. Its my understanding iron heads are preferrable to port.
warmeck
Jul 17, 2015 01:36 PM
cmsmith
Jun 4, 2015 07:35 PM
NewsBot
Jan 8, 2015 11:29 PM
