Shoebox wiring?
Old Aug 24, 2003 | 11:43 AM
ChevyIron's Avatar
Shoebox wiring?
I am installing a water temp gauge,If you could tell me which wire off the pcm I use for the signal wire.Thanx in advance.
Old Aug 24, 2003 | 01:26 PM
There is no wire off the pcm that you can use. A temp gauge should have it's own sensor and does not rely on the pcm for any info, i.e. the gauge you are installing should have a sensor you put in the engine to drive it.
Old Aug 24, 2003 | 02:43 PM
ChevyIron's Avatar
Thanks Rob I did a search found out what I have to do I appreciate you helping me out.
surreybrad
Apr 22, 2015 06:40 AM
greenzee28
Mar 26, 2015 09:13 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
