Shoebox, need help
Old Jul 4, 2004 | 01:07 PM
SantaCruz163's Avatar
Shoebox, need help
Do you have the part number for the upper heater hose for a 95-97 F body? It's the hose coming off the top left of the water pump and has a bleeder screw on it.
Old Jul 4, 2004 | 01:32 PM
The hoses and coupler with the bleeder on it are available separately. See if this helps.
Old Jul 4, 2004 | 02:03 PM
Well I have a small hole between the water pump outlet and the bleeder section. What would you reccomend I do to fix it?
Old Jul 4, 2004 | 08:28 PM
Just get that hose and trim off the swaged collar that is on the bleeder pipe. Then, you can put the new hose on and secure it with a hose clamp.
Old Jul 5, 2004 | 09:52 AM
Thanks alot shoebox, you always have an answer
KYWes
Jun 14, 2022 06:52 AM
gelbza
Jul 12, 2015 08:10 AM
mrz28M6
May 16, 2003 04:24 PM
rmackintosh
Mar 18, 2003 05:20 PM
Coop1
Feb 27, 2003 08:10 PM
