Shoebox...need a bolt size please
Old Feb 4, 2004 | 11:10 PM
94_Camaro_LT-1's Avatar
Ok bud I was wondering if you know the size of the bolt that goes on the drivers side bottom of the block... same thread as the knock sensor on the left side (a coolant drain plug). I was at speed shops and home depot today with the knock sensor and no one had the thread. If I can get the dimensions I can call this Bolt & Nut place... thanks!
Old Feb 4, 2004 | 11:18 PM
Hardware store is where you want to go. It is a tapered pipe plug. The book says 1/4-18 NPTF but it sure seems bigger than that (more like 3/8 or 1/2 to me). Too bad I don't still have my engine out, I could have measured it for you.
Again, take your knock sensor with you.
Old Feb 4, 2004 | 11:24 PM
THANKS
Old Feb 5, 2004 | 06:39 AM
Mtrhds94Z's Avatar
It's 1/4 x18 NPT [National Pipe Taper Thread]for the block drains..
Any hardware store[AND home Depot or Lowe's etc..] will have one..
Ask for a brass 1/4" tapered pipe plug..
Old Feb 5, 2004 | 07:40 AM
So it really is 1/4, eh?
Old Feb 5, 2004 | 10:53 AM
OK thanks bro, Im gonna check it out later today after class
Old Feb 5, 2004 | 02:54 PM
Mtrhds94Z's Avatar
Yes it is Rob..
I think the confusion comes from thinking 1/4" BOLT sizes as compared to the 1/4" pipe plug sizes[no comparison really]
1/4" x [blah] machine threads [on bolts] are about 5/16" OD
1/4" male tapered pipe plug threads are a hair over 1/2" OD [due to that 1/4" being the ID of the pipe [think galvanized plumbing pipe.. or 'black' gas pipe sizes, etc..]
Old Feb 5, 2004 | 04:21 PM
Yes it is Rob..
Yeah, that always confuses me. I am not a real engineer, "I just play one on T.V.".
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
