shoebox i need your help
Old Apr 29, 2004 | 08:55 AM
pappasmerf18's Avatar
ok i am trying to do a manuel fan switch going by your obd1 diagrame but what i need to know is off what of the ecu do i connect to what bundle of wires the bundles are labled z b and all that. what color wires is it also i am so confussed and i need this fan switch to work bc my sensor is out to turn them on and i need fans untill i can get the sensor
Old Apr 29, 2004 | 08:58 AM
HBHRacing's Avatar
1 you can use this site to find out where to tap into the relay grounds http://users.oco.net/xero/fanmod/
2 if you mean your coolant temp sensor is bad and teh fans are not coming on cause of it you need to be careful. that sensor is also a part of fuel control. I'm sure you will wanna hurry and get that replaced
Old Apr 29, 2004 | 09:00 AM
See my reference to connector C100 in this post:http://web.camaross.com/forums/showt...51#post2094651
Old Apr 29, 2004 | 09:36 AM
ok i got the sensor 25 dollars im putting it on i hope this will fix it
Old Apr 29, 2004 | 09:39 AM
HBHRacing's Avatar
if not just go back to that link that Rob just posted. has a lot of info for the fan issue
KYWes
Jun 14, 2022 06:52 AM
gelbza
Jul 12, 2015 08:10 AM
mrz28M6
May 16, 2003 04:24 PM
rmackintosh
Mar 18, 2003 05:20 PM
Coop1
Feb 27, 2003 08:10 PM
