Shoebox i need a diagram.
Old Aug 11, 2004 | 08:58 PM
ChevyTuffD.A.'s Avatar
I would appreciate it if you could give me a picture or diagram of the passenger side of the intake manifold on a 95 lt1. Specifically of the evap thing where the two vaccum lines come out. I think i may have them backwards and my be causing my problem but i am not sure and want to see a diagram. Thanks, Dustin.
Old Aug 11, 2004 | 09:16 PM
Dave89IROC's Avatar
Re: Shoebox i need a diagram.
From Shoebox's site
if you search his site, you can find lots
Shoebox's site
Old Aug 11, 2004 | 09:18 PM
Ok i think i have them backwards, could that be causing my idle problem and causing my car to die every now and then?? I have the hose that goes into the evap line going into the throttle body and then i have the hose that goes into the throttle body going into the evap line.
Old Aug 11, 2004 | 09:26 PM
Dave89IROC's Avatar
it might
I think the vac line as you have it is vented to atmosphere with the solenoid closed
Old Aug 11, 2004 | 10:41 PM
Hook them up right and see! If they are backwards on a 1996 or 1997 it will cause a trouble code.
The sticker on the top of the radiator cover will also tell you how to route the hoses.
KYWes
Jun 14, 2022 06:52 AM
gelbza
Jul 12, 2015 08:10 AM
mrz28M6
May 16, 2003 04:24 PM
rmackintosh
Mar 18, 2003 05:20 PM
Coop1
Feb 27, 2003 08:10 PM
