shoebox....fulepump...u know what i want lol
Old Jun 15, 2004 | 10:40 PM
CamaroSS30thAnn's Avatar
well i am almost certain now that my pump is bad......but does it throw a code on an OBDll car?
also need the P/N for fuel pump on 97?
Old Jun 15, 2004 | 10:45 PM
There are no codes directly related to fuel pressure. If I was going to buy a pump, I would look into Racetronix products.
Old Jun 15, 2004 | 11:35 PM
camarokid24's Avatar
I would also suggest a racetronix pump I just installed mine last sunday, be advised though you will not get instructions. In the kit you get all the things to change the pump but no instructions. LOL I know it is a fairly simple install but some things are diferent with the pump than a factory replacement one. I emailed racetronix to try to get the instructions but got an auto responce telling me to contact the distributor that I got it from . So I call Thunder Racing and they tell me that racetronix dosen't supply them with there kit because they were told "if you need instructions to change a fuel pump, then you shouldn't be changing one"
I will say though that Thunder racing has excellent costumer service . I got mine delivered the next day for $190.51 Thunder Racing
Old Jun 16, 2004 | 01:12 PM
i just need the stockpart number....thanks
Old Jun 16, 2004 | 05:34 PM
Jkren's Avatar
Dont replace it with the stocker....
Old Jun 16, 2004 | 06:18 PM
stonez96z28's Avatar
why not.....the man want's a stock pump.
Old Jun 16, 2004 | 06:28 PM
Racetronix's Avatar
Pay more for less?
Old Jun 16, 2004 | 06:38 PM
camaroz28_97's Avatar
my check valve is leaking. does this kit come with everything or JUST the fuel pump???
Old Jun 16, 2004 | 06:50 PM
Racetronix's Avatar
Everything?
The $150.00 kit comes with everything needed to replace the pump?
The checkvalve is built into the pump.
Old Jun 16, 2004 | 07:36 PM
so this would fix my problem sorry this is one of the few things i haven't taken appart on my car where do i order
Old Jun 16, 2004 | 07:39 PM
Originally posted by Racetronix
Everything?
what are my benifits of getting the racetronix over the stocker?
howdo i order and is ther over night delivery?
im doing the "trap door" method to save money.....any reason to drop the tank with the new hardware?
were can i get a racetronix? (walbro)
Old Jun 16, 2004 | 07:47 PM
GM only lists the pump as part of a "module". GM PART # 25164521. It is the whole assembly of pump, sender, strainer pipes and electrical harness. $412 retail, $206 wholesale.
Old Jun 16, 2004 | 07:56 PM
how about the P/N for teh IAC?
i really appreciate this guys ....thanks
Old Jun 16, 2004 | 08:24 PM
...on my part numbers page...
97 IAC GM PART # 17113188
Old Jun 17, 2004 | 12:20 AM
sorry man i must have skipped over it
