Shoe box: I'm still baffled.
Old Aug 18, 2003 | 02:47 PM
BUBBA's Avatar
Still trying to figure out what's what with the baffles. I have your diagram showing the upper and lower. My "mechanic" apparently decided not to put them in correctly, so I'm stuck with looking at the 2 baffles about 2" apart from connecting to one another. The top baffle is underneath the lower baffle. Looks like it should be on top.
Do I need to go to a bodyshop to get this damn thing corrected? I just can't stand it when something isn't put back together correctly.
Any instructions on how to fix this sucker will be greatly appreciated.
Thanks.
Old Aug 18, 2003 | 10:03 PM
I can email you a few pics, but I am not sure if they will help much. I don't have an overall view.
Old Aug 19, 2003 | 10:02 AM
BUBBA's Avatar
Thanks Shoe. It's sounds simple, but when someone doesn't put something back together correctly and in the order it should be, it sometimes requires extensive work to to undo the damage.
I'd appreciate any pics or advice. As I mentioned, the top baffle is under the bottom one. Perhaps you tell if it should be on top, instead.
The mech. even stripped the middle bolt hole that holds down the top of the radiator cover.
If I was ever to advise someone about modding a car, I'd say 2 things. "Never mod a brand new car" and "Do your own work".
Thanks again for responding.
Fatdog2
10
Jun 3, 2015 11:38 PM
CARiD
Apr 8, 2015 08:08 AM
v6maro
Apr 29, 2003 12:28 AM
