Shocks & Springs REPLACEMENT... FEW QUESTIONS...
Old Jul 2, 2004 | 10:49 AM
Hyperspeed97z28's Avatar
Question Shocks & Springs REPLACEMENT... FEW QUESTIONS...
Picked up a set of 1LE springs and shocks.. (Decarbon's)
Anyways...
Currently I get squeaks from the rear which I know already is the springs.. What can I put on the new springs in the rear so I have no squeeks ?? Also does anyone have any tips for the fronts?? The rears are simple as can be but I've never got into the front end before...
Any tips and or more parts I'll need to assist in my install would be great..
My goal is to atleast get my Rear LCA's in and the Rear springs/shocks...
Will the car ride funny with new parts in the rear but not the front?
Any INSTALL GUIDES?? LINKS ??
Thanks in Advance...
Old Jul 2, 2004 | 11:08 AM
Gripenfelter's Avatar
On the front you just need to remove the lower balljoint to get the strut assembly out.
You might not be able to get the nut off the top of the assembly once you get it out in which case you will have to cut it off with a dremel etc.
Old Jul 2, 2004 | 11:58 AM
So should I replace the ball-joints as well ??
Are these hard to replace ?
Cheap ?
Fastbird93
Jun 3, 2015 05:56 AM
KYWes
May 22, 2015 08:48 PM
BLK1997Z28
May 1, 2015 12:23 PM
Charged
Sep 25, 2002 09:28 AM
Pro Stock John
Aug 1, 2002 09:18 AM
