Shims,retainers,and locks..
Old Feb 2, 2007 | 03:44 PM
camarozz95's Avatar
I am looking in doing 1.6 rockers think i'm going for the crane gold SA no plan to do cam in the near future. so the question I have is i was going to get the lt4 springs, but i saw a kit that came with the springs shims retainers and locks. Do I need all that or will the lt4 springs fit by themselves?
Old Feb 2, 2007 | 03:49 PM
truedualws6's Avatar
LT4 Springs
If your heads are stock the LT4 springs will drop in, in place of the stock springs.
It's advisable, depending on the mileage, to replace the seats, retainers and
locks since they do not add that much cost. Also replace the valve stem oil
seals while you are in there.
Old Feb 2, 2007 | 03:50 PM
camarozz95's Avatar
ok cool how much are the valve stem seals and where can you get them? Car has 99k now
Old Feb 2, 2007 | 05:34 PM
seawolf06's Avatar
Get some Felpro seals from Autozone.
Old Feb 3, 2007 | 11:01 AM
GMPP Info
Here is a good link to the GMPP catalog pages on this topic:
http://www.s-series.org/htm/tech/GMP...ts/061-065.pdf
Shoebox also has great info on this subject:
www.shbox.com/ci/valve_spring_swap.html
Here is the part numbers for the valve stem oil seals that I used when
I did the cam swap:
Intake - 460483
Exhaust - 10147883
And here is another link that shows PNs and comparisons of the ZZ series
engines:
www.crateenginedepot.com/pdfs/SB_zzengine.pdf
Nutty's96
Dec 21, 2015 06:25 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
karpetcm
Aug 14, 2015 03:02 PM
Cam's maro
Aug 11, 2015 07:45 AM
Aug 5, 2015 08:35 AM
