shifting probs
Old Feb 28, 2006 | 07:04 PM
Hark_z's Avatar
shifting probs
My car wont shift.
Sat night I let my fuel get too low and the car started growning, I went and filled up with gas and was fine for the night and nothing else happened. Two days later I started it up and the car wont shift. I thought I sucked dirt from the bottom of my tank into the fuel filter and who knows where else.. I swapped out the filter and put a new one on and the car still has the problems. Basically, the car wants to be in third gear. When I am stopped and remove the car out of park into reverse of drive the tranny and whole car actually jerks.. On the street it is like I do not have a first or fourth gear. So it seems like something is clogged but yet why does the car favor third gear and not want to shift. Next I was going to try and run injector cleaner through the system.
So obviously my car has a huge problem, heres everything I can think of:
transmission is blown
shift solenoids are off
something is off with my tuning/PCM
What are your guys opinions????
I have a H/C package ready to install and this starts happening!!
Old Feb 28, 2006 | 07:53 PM
OBE1 95Z28's Avatar
Re: shifting probs
If your car runs fine in 3rd gear, I don't think you have a fuel problem. To be sure you should hook up a fuel pressure gauge to the Schrader valve on the fuel rail and verify you have around 40 psi with the vacuum hose removed from the fuel pressure regulator. Also a good idea to tape the gauge to the windshield and see if the pressure holds under load.
I think you have a tranny issue.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
