Shavings around the RMS area..?
Old Mar 31, 2008 | 12:20 PM
97BBlackZ's Avatar
So i've been searching for a problem to my noise and i've had the tranny out and everything in order to fix my RMS and check some other sutff.
Now down in the hole that i guess the Pilot Bushing would go in? There are round metal shavings in the shape of a coil, kind of like a spring, and and a few small round pellets laying in the hole. What would cause this?! And would this be the cause of a clanking sound i'm getting while the engine is on.
I'm trying to get pictures but i can't get the camera to work on my computer.
THanks,
B
Old Mar 31, 2008 | 12:34 PM
AHARTZ28's Avatar
looks like your pilot bearing went out. remove it and install a bushing
Old Mar 31, 2008 | 12:55 PM
97BBlackZ's Avatar
Cool. well good to know.
Would that cause a loud clanking sound? Rather the clutch is in or out?
Old Mar 31, 2008 | 01:00 PM
AHARTZ28's Avatar
it will cause a rattle
Old Mar 31, 2008 | 01:02 PM
97BBlackZ's Avatar
a very loud one? or anything that sounds familar to this?
http://s21.photobucket.com/albums/b3...t=P3190001.flv
Old Mar 31, 2008 | 01:45 PM
Sounds like some damage is being done by whatever that is. Your pilot bearing may be going nuts.
Old Mar 31, 2008 | 01:48 PM
ssbowtie1's Avatar
Wow. Have you checked to make sure your none of the rockers fell off the studs?
Old Mar 31, 2008 | 02:09 PM
97BBlackZ's Avatar
Yea and i still can't figure it out =((
You think there could be something wrong with the crank?
I've checked the rockers and lifters. Adjusted them twice and replaced all the lifters on the passenger side.
I took a screw driver to all the rockers and they all sounded about the same. and to varies other places with no conclusion.
The cars been down for quite a few days. And its long past being a pain in the ***.
Old Mar 31, 2008 | 03:02 PM
Based on what you already found, the pilot bearing is the prime culprit. You will have to pull the transmission to take a look. AHARTZ28 gave you the scoop.
Old Mar 31, 2008 | 09:45 PM
97BBlackZ's Avatar
Cool deal. I already have the trans pulled. I'll be replacing it tomorrow and we'll see.
I'm keeping my fingers crossed
$hawn
Dec 15, 2002 02:19 PM
95m6
Dec 1, 2002 09:24 AM
sleeperZ96BT
New England Area
Sep 23, 2002 08:13 PM
sleeperZ96BT
Sep 23, 2002 02:02 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
