Is this setup worth $2150?
Re: Is this setup worth $2150?
Well unless the guy has receipts for everything i would just assume the internals are bone stock too. If so you can buy rebuilt stock long blocks for $15-1700 so throw in the price of
hooker LT's $500
CC 305 $200
A better than stock chain if he used one $100-200
Valve springs $150
Electric water pump $150
roller rockers $250
You saved about $400 over buy the parts new, and then you would know what you have.
hooker LT's $500
CC 305 $200
Valve springs $150
roller rockers $250
Originally Posted by Z95m6
Ditto, you got screwed. Port matched heads = stock heads. I would say 330rwhp is probably about right. No way you can get 500rwhp on ported GM LT1 castings if you are NA. I would say 400rwhp is about the most you can really get with just ported heads and a big cam.
Some guys on this board with just ported heads and a big cam are pushing 425-455rwhp on this board with LT1s.
It turns out that I was told the heads are stock. I did not pay attention. I knew it was too good to be true.
I'm thinking about giving Lloyd Elliot a call now.
mark0006
Aug 29, 2015 09:45 AM
