setup opinion???????????????????????
i have a 95 formula m6 with pacesetter lt's y-pipe no cats borla cat back spec stage 3 clutch and flywheel 4.10 gears i recently bought a powerdyne 6psi supercharger. my ? is im going to add a 52 mm throttle bodie(how about the ones that are cheap on ebay anyone have these with good luck) walbro255 in tank fuel pump and 40 lbs injectors with possible a lt4 hot cam kit and a good tune. whats your opinion on this setup and what type of rwhp and rwtq can i expect from this setup the car only has 56000 on the clock i know the dangers of the blower but i wanna know if this setup will work well together
Re: setup opinion???????????????????????
LT4 cam is not optimum for a blower; I'd look into a blower cam.
4.10's with a blower is going to be nothing but wheel spin in first gear on street tires.
